Brought fuselage and wings out to the front yard and squared it off, pinned up the wings to the fuse and set the wing on the support frame. Set up and cut the wing struts to length and drilled attach points to 1/8" and held together with wing nut cleco's. It was derk by the time we finnished. Took everything apart again and put everything back in the garage.
