Brief Description: Bottom skin and trailing edges.
Primed the bottom skin and fit the trailing edges, de-burred and primed. used the string method to keep the trailing edges in line. Cut and primed the leading edges, I need to decide how i'm going to run the cables through the wing befor I install the leading edges.
