Installed left tire ass'y and installed it on the gear. Came up with a unique way to install the bungies, it takes about 2 minutes to complete the whole process. Step 1. get a piece of 1 1/2" pipe aprox. 36" long and cut a 45 degree angle on one end. Step 2. install both bungies on the back side. Step 3. clamp a set of visegrips on the shaft inside the mount to stop the shaft from sliding. Step 3. pass the pipe through the loop in the bungee and up to and over the shaft. Step 4. Pry the bungee into place, ensure you hold on to the fuselage as it will move while prying. Repete for the other side, install keeper bolts and admire your work.
