Recieved the door lifters today, installed the ball brackets 100mm from the door frame and 235mm from the bottom of the door frame. The shocks aren't the same strength as the right one lifts a little quicker than the left, I might have to adjust the left one down on the window frame a little but I don't want to make any more unsightly holes in the frame, I think I should have installed the brackets at 120mm. Lifter part #819-5519 and lift bracket is 735-1898 at NAPA.
