Brief Description: Continued on assembly of H-Stab
Trying to bolt D-89 to bulkhead 7 but the hardware kit is missing these bolts, this seems to be an ongoing issue with this kit. I guess i'll have to break down and put in an order at Aircraft Spruce. Installed temp. 1/4" bolts to hold D-89 in place for now, i'll replace them when my order comes in. finnished drilling all holes to 1/8 and then drilled out all the holes that require a 3/16th bolt to that size. Used 3/16 wingnut clecos to hold P-D-75 in place. Put the skin on the right side and marked out lines for the rivets. E-mailed Tony to see if I could trim P-D-75 to match the leading spar as it is wider than the spar.
