Bruces S-19 Build Log
S-19 Venterra
Fiberglass Tip for V
8-6-2013
Layed-up a fiberglass fwd tip skin
Bent the lay-up table over a pipe same as used for the metal tip skin and layed-up the fwd tip skin. Same skin laminate thickness as the aft skin.
Vacuum baged skin
peel ply can be hard to remove
finished skin ready to trim
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
