Brief Description: Made support brackets clips for control stick wiri
Made a two support brackets for the stick wiring harness plug. It required a bit of thinking to come-up with a secure mount point since nothing is specifically provided on the control tube. I could of simply straped the plug to the tube using the wires but I decided instead to build some brackets to hold the plugs and strap the brackets to the control tube. The brackets sockets into the existing holes on the control tube opposite to its mounting bearings. This provides a nice secure spot for the plug. Last pictuer jumps ahead to how the brackets are going to be mounted. I might be over-thinking this....
