Bruces S-19 Build Log
Date:  12-28-2013
Number of Hours:  4.00
Brief Description:  Made up the ELT wire harness
I don't think it's possible to solder a 24 AWG shielded wire harness to the back of a mini-DIN connector. Even if you had the eye sight of a 12 year old, the steady hand of a brain surgeon and the patience of Job, the wire strands are not going to fit in that little hole. I tried to open up the hole with a needle, and cut most of the strands but all I managed to do was mutilate the entire stock of Fry's mini-DIN connectors. I need a method that requires absolutely no skills whatsoever so that even I can do it. -- I then noticed that a female D-sub connector pin fits nicely over the DIN pin. Eureka! It will require some modification... I'll finish up tomorrow.
That wire is not going in that hole
All I'm doing is bending and melting pins
Hey! a D-sub pin will work
