Brief Description: Designed Dynon ADAHARS support bracket for wing
Perhaps the easiest place to put the Dynon ADAHARS sensor is in the fuselage behind the bagagge compartment, but when I measured the magnetic effect using a compass, with and without my steel frame bike inplace, I found that the most benign location is in the wing inboard of the fuel tank. I made up a paper mock-up of the support bracket and checked for accessability. I will design the support so that it can carry two ADAHARS sensors piggy backed on top of each other.
