Bruces S-19 Build Log
S-19 Venterra
Aileron
7-8-2011
Started Aileron Assembly
Discovered that it was true- you need the ailerons to set the hinge position on the wing rear spar. I pulled the wing up to the ceiling and left it hanging above the work bench and started on the ailerons.
First step on aileon assy
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
