Bruces S-19 Build Log
Date:  7-24-2010
Number of Hours:  6.00
Brief Description:  Static line routing
I made a bracket out of .020" 2024 sheet to support the static line tee fitting I got from safeair. Then I made a cutting guide to make a clean vertical cut in the static line tube with a excacto knife blide pushed through the oak block in image 3 with a bench vise.
Static line Tee bracket
bracket installed
bracket installed
Tube cutting aid
Tube cutting aid
