Spent this week on measuring twice, triming, then measuring twice and drilling the upper side skin longeron. It was hard to figure out from the plans the foward splice arrangement. Fortunately there was a nice picture on the RansClan website. Installed the trim tab servo. Watch out for the lower right hand mount screw. The hole is drilled thru the steel bath tub fitting. It is very close to the side wall, so you must drill the hole carefully. The nut on the backside will be difficult to get too if the servo needs to be replaced in service. If the ajacent 3/16 inch bolt is removed first, I think it will be OK.
