Brief Description: Set up work bench blocks and trued wing
I spent most of the day making sure that the wing was level and true on 3" blocks. The wing is suposed to have no twist. I Set the Front spar on blocks using a laser level to insure that the three blocks were in line, and then used the digital part of the level to insure that the angle from the front spar to the rear spar was zero degrees at all trhree plocks. Then I used a string through the front and rear spar alignment holes with fishing weights and a carpenters square to insure that the line between spars is 90 degrees. Gotta get this part right!
