Bruces S-19 Build Log
Date:  8-16-2009
Number of Hours:  8.00
Brief Description:  Started Trim Tab construction
To check on the trim tab hinge position of the horizontal stabilator, I started construction of the tab. Clecoed the tab together and drilled to full size. The rivets through the spacers in the center hinge rib are a tight fit, so I un-bent the rib, then riveted the two ribs together and bent the rib flange back. This seemed to work well.
Drilling the tab spar hinges using the Stab hinges for position
Riveting the center rib with bent flanges for clearance
Trim Tab under construction
