Brief Description: First attempt to fix the root plate holes
Flipped Front spar root attachment plate around to proper position. All the pre-piloted holes that were drilled to full size line up perfectly. The 4 holes that were hand layed-out for the rib clip do not line up well. The holes in the front spar and attachment plate are the critical holes so I wanted to preserve those holes and drill thru the spar into the 0.025 thick rib clip. This would elongate the holes in the clip, but better in the clip than the spar and plate. I don’t know why it happened, but when I tried this the clip holes caused the drill bit to elongate the holes in the spar and plate. Well that wasn't the plan. I said "O - shoot" or something to that effect. Need a plan B.
