Installed upper hinge bushings per the instructions. Reamed out the bushing with a 3/16" reamer held in a vise grips pliers by hand. Figured out the rivet gun and assembled the rudder frame. Installed the stainless rivets common to the steel lower hinge torgue tube and the aluminum frame wet with primer.
