Bruces S-19 Build Log
Date:  3-28-2009
Number of Hours:  0.00
Brief Description:  Work bench details
The table is 12 ft X 4 ft. The top surface is made from 3.4" partical board, one 8 ft and one 4 ft length, screwed to a subframe made from 1 X 6" pine alone the long sides and 1 X 4"cross members at every leg as well as midway between legs. The leg where the panels join has two cross members. The end legs are made from two 2X4's nailed to form a "L" shape. The inner legs are made from two 2X4's nailed to form a "Tee" shape. The lower shelf is made from 3/8" scrap ply wood on a subframe similar to the top except made only from 1 X 4's. The table is 34 inches high. The bottom shelf is 12 3/8" from the floor. This gives enough space under the table to sweep the floor and for additional storage.
The table top overhangs the sides by 1.5" so that parts can be "C" clamped to the top.
End legs
End legs
Inner legs
Inner legs
Top overhang
Top overhang
