Bruces S-19 Build Log
Date:  2-8-2016
Brief Description:  Rotax ECU Wire harness Firewall penitration
Made up some bits of .016 stainless sheet and tube so that my friend Tom could weld a firewall penitration plate for the engine ECU harness. This took two tries as we didnt have a big enougth heat sink and the first attempt at welding the thin sheet to the tubes warped badly. Thanks Tom!!
I will stuff the tubes with fire-seal on final installation.
Bits
Bits
welded and trimed
welded and trimed
installed w/o fire seal yet
