Bruces S-19 Build Log
Date:  11-9-2015
Number of Hours:  1.00
Brief Description:  Built a battery bos
With the fuse box where it needed to be the battery needed to be a little more outboard than the kit location. I wanted to be sure there is the ability to remove the battery, remove the fuel pump cover, and have adaqute distance from the hot voltage regulators to adjacent components. This required a new battery box, which I built from .032 aluminum sheet. I sized it for a PC680 or EarthX LiFe battery. A upper retainer beam will be added with nutplates on the ears of the box when I buy the battery.
Battery Box
Battery Box
Installed
Installed
