Bruces S-19 Build Log
Date:  9-16-2015
Number of Hours:  8.00
Brief Description:  Tom welded a motor mount
I wasn’t happy with the engine mount (Firewall to Rotax ring mount) that I had welded for the 912is engine. It had slag inclusions, pin holes, a crack and was badly warped. It was a good attempt, but apparently the MIG welding process should of been done with TIG.
My friend Tom-the-welder from the local Snohomish EAA chapter volunteered to weld me a new mount, if I could build a jig, and cut a set of new tubes.
Mark Pringle at Rocky Mountain Kitplans was kind enough to let me barrow the welding jig that George Happ built for his 914 powered S-19 ( the 914 engine also uses the same Rotax ring mount).
So I picked up his jig in Utah when I was on a road trip to Colorado to visit family, I will return the jig when Mark is out here delivering a plane with his trailer. I ordered a set of CNC cut tubes from the same vendor he used (they still had the dataset, VR3 engineering in Stratford Ontario). When everything was ready I loaded up the jig at took it to Tom's. Tom was able to weld the mount in about 4 hours.
It’s nice to have friends with skills who aren’t afraid to use them. Thanks Mark, Thanks Tom!!
Loading the jig
Loading the jig
Welding in progress
Welding in progress
Tom and the finished mount
