Bruces S-19 Build Log
Date:  4-26-2015
Brief Description:  Drilling Conopy frame
I drilled the Canopy Frame capture strips on center line and then match drilled them into the frame. Somehow the holes in the frame ended up off-center. Fortunitly they were under size holes. Spent some time jigging up the frame to my drill press so I could pull the holes back to centerline as I drilled them up to full size. It worked out OK in the end.
center drilled captue strips match drilled into fram
drill press used to pull holes back to centerline
