Brief Description: Drilled instrument panel mount and roll bar suppor
Drilled out the instrument panel mounting holes to 5/16" dia. Found I had to step drill in 1/64th increments to keep the drill bit from grabing. I bought some HSS bits from Lows to do this. I will do all the larger holes in the future using smaller steps, since this results in less chatter and a better quality final hole. I also drilled the lower end of the roll bar brace to full size finished deburing parts.
