Brief Description: Seat & Baggage floor and shoot -Not another one!
Drilled up the center bearing block nut plates for the flap actuation lever. Started to install the seat and baggage floors. The pre-drilled pilots in the floor panels don't match the predrilled pilots in the rear spar upper flange. After a little head scratching I discovered that the flange (KPRU0409 "Angle-Rear Spar Bulkhead" is installed wrong.The leg with many predrilled pilot holes should of been installed against the predilled spar web. The leg with pilot holes at rib stations only should of been the floor leg. Shoot. From the Figure on page 05A-01 I thought I installed it correctly. I think the Figure is misleading. Well, It appears I will need to order my first replacement part.
Flap lever bearing blocks and rear spar flange showing the flange that should be fliped
Holes in flange do not line up with holes in seat and bagage skins
