Bruces S-19 Build Log
S-19 Venterra
Transfer drilled the longerons to the side skins
Marked the longerons 0.45" from the aft end, and using the aft hole in the gusset,temporary clecoed in place, as a guide located then drilled the longerons to the side skins.
Longerons cleco'd in place
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
