Brief Description: Trial fit of a breakdown bicycle
I invited some cycling buddys over to trial fit a full size break-down bike aft of the seat area. It looks like two bikes will physically fit, and and there should be enougth access to install and remove the bikes. I will have to extensivily modify the rear bulkhead close-out (non load carrying). I need to look into the weight and balance impact and if that is acceptable, design some mounting brackets.
bike fit in 1/2 the fuse. width
wheels and frame extend past the bagage area close-out
