I made up this tool to help push blind rivets it tight or misaligned holes. Its just a dowel with a hole drilled in the center for the rivet stem. Its very handy and works better than pushing the rivet in with the rivet puller. The hole is drilled at an angle through the center of the dowel breaking out of the side. This allows me to push from an angled position. I wraped the end of the dowel with straping tape to prevent splintering.
