Bruces S-19 Build Log
Date:  2-15-2009
Number of Hours:  0.00
Brief Description:  Usefull tools 2
1, By far the most useful tool is the Ransclan website, www.ransclan.com.
2, A set of drill stops. I would consider these to be essential. I use one on almost every hole drilled.
3, A laser level has been extremely helpful - and promotes peace of mind.
4, I use a 120 volt Craftsman 150 psi oil lubricated unit rated at 5.8 cfm at 90 psi, model 919.195413. Oil lubricated is quieter than oil-free. Mine is only about as noisy as a washing machine, which is important since I use it at night in my garage, in a tightly packed neighborhood.
5, Goodyear 3/8” dia PVC air hose. I originally tried a polyurethane air hose which is nice and light weight, but the coils are built into the hose and it would not lie flat on the floor. This was such a trip hazard that I changed to the PVC hose.
6, A 1/8” Burraway tool, Wicks tool supply 2125, is very useful for enclosed backsides.
7. The 22022 Royal multi burr tool is very useful for edges and lightning holes.
8, Sioux DR1412 palm air drill. A palm air drill is very small and light weight. It makes it easy to get into tight spots. Considering the number of holes to be drilled, I think a good drill is a worthwhile investment. By far the best price was Brown tool supply.
9, Cleco clamps, I’ve found the 1” ones to most used.
10, A right angle drill attachment, I was worried about this at first but it works great.
12, A bench belt sander. Based on Glenn’s recommendation, I got one at Harbor Freight, so far I’ve found this to be more useful than the bench grinder.
