Brief Description: Started fiting VS Leading Edge skins
Wes came over and helped with opening up the side skin holes to full size. Then I layed out the fastener lines for the leading edge skin. Drilled out the right hand side to #40 and clecoed. Fliped the stabliser over and tried to align the right hand side per instructions using straping tape. Wow hard to align! Started to grind down the nose of the leading edge ribs as required. Still no-go. I'll try again tomorrow.
