Brief Description: Fixed the elongated holes in the front spar
Jigged up the front spar assembly in the drill press and very carefully drilled the elongated/ missaligned 1/8 inch dia holes true to 5/32 dia. (#21). Was carefull to keep the rib clips aligned. Worked great, now I have nice round holes. Riveted the front spar assembly, I installed all steel rivets wet with primer.
The finished repair rivets c/t the rib clip and spar web
