Bruces S-19 Build Log
S-19 Venterra
Rudder skining
Set-up rudder trailing edge in jig. Transfer drilled rear spar to #40 then drilled full size to #30. Aligned skins on rudder substructure using #40 cleco's.
Set-up and drilled rudder trailling edge in jig
Aligned skins on substructure
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
