Bruces S-19 Build Log
Date:  4-19-2009
Number of Hours:  4.00
Brief Description:  Riveted Rudder Frame
Installed upper hinge bushings per the instructions. Reamed out the bushing with a 3/16" reamer held in a vise grips pliers by hand. Figured out the rivet gun and assembled the rudder frame. Installed the stainless rivets common to the steel lower hinge torgue tube and the aluminum frame wet with primer.
Marsen V2 Rivet gun, works great.
Rudder lower hinge rib
First Assembly!
First Assembly!
