Bruces S-19 Build Log
Date:  8-4-2018
Number of Hours:  1.00
Brief Description:  Final Cowl Trim
Trimed and installed the upper cowl. Still need to cut a oil door.
I used the kit supplyed 1/4 turn Southco Dzus fasteners for the cowl to firewall flange joint. I used #8 screws and fixed (non-floating) nutplates with #11 holes for all the fasteners common to the horizontal upper to lower cowl joint. I have heard reports that the Southco fasteners are a bear to engage on the very flexable upper to lower cowl joint.
Triming
Triming
keep it tight
keep it tight
looks good
looks good
