Bruces S-19 Build Log
Date:  7-24-2017
Number of Hours:  1.00
Brief Description:  trimed and installed Rear Baggage bulkhead
Trimed and installed the reat baggage bullkhead. This was easy but tedious. Lots of fit-trim-repeat.
The way the bukhead is formed makes it impossible to pick-uo the locations of two of the nutplates on the lower sides. I added two screws and nut inserts to the floor for added strength. I had also added a cargo tie down fitting plate to the back of the floor frame. This worked OK.
Rearbulkhead showing additional  2 screws,  tiedown plate and area where there are no screws.
