Bruces S-19 Build Log
Date:  7-5-2017
Number of Hours:  1.00
Brief Description:  Installed windscreen
spot-faced part-way into the backside of the fiberglass hold down strip to clear over the top of a few upper panel rivets. Clamped and appied heat to the ends of the hold down strip - then hand pressure to the free-standing leg, to remove a bit more of the warp out-of-plane. Then sealed with paintable DAP sealant and riveted. Rivits were installed wet with sealant.
The windshield hold down strip is a pretty much perfect fit with no warp at the ends.
light spot face on backside to clear rivet head
heat gun clamp and bend leg to remove warp
windshield installed
Copyright © 2001-2018 Matronics. All Rights Reserved.
