The S-19 cabin heater runs off of a shroud around the muffler. when the cabin heat is off the hot air is dumped forward of the firewall. The voltage regulators are mounted on the firewall and I want to keep them as cool as possible so I want to route the hot air out the bottom of the cowl. Made up a little tube to conevt the existing dump port to a flexible air line.
