The electrical system is almost finished. Just one more switch to wire. O yea then I need to buy a the transponder and wire it, O and then a ADSB receiver, It never ends... The fault indicator on the battery BMS lights up when there is no power on the system and the indicator wire is attached to the Skyview EMS. It works as advertised when the airplane electrical system is on. I don't know if this is a problem or not, its just a little LED but i don't like it being lit continuosly when the power is off the airplane. I was having trouble finding a crimper for the CPC series 3 electrical power feeder terminals for the fuse box X3 connector. A crimper and die cost about $2,500! Not going to happen. I checked around for someone who could crimp the three wires for me without much luck. Finaly after weeks, I was informed that this is a standard tool at any certified aircraft avionics shop - DUH. Crown aviation crimped the three wires for ten dollars. Great!
