Bruces S-19 Build Log
Date:  10-11-2015
Number of Hours:  6.00
Brief Description:  Fuel Filter bracket
Fabricated a bracket for the fuel filter, by-pass check valve and pressure sender from 0.050 6061-T-6 aluminum. This took some time with a cardboard mock-up and then 2 iterations of scrab thin aluminum to get right becaule of the tigh fit between the fuel pump assy and the side of the fuselage as well as the need to locate and support the by-pass check valve and fue pressute sender for the Dynon display.
Bracket
Bracket
Same
Same
Installe
Installe
