Brief Description: Fabricated first cockpit fuel line
Since I have a fuel injected engine I have to plump bothe fuel supply and return lines. I decided to use rigid line because of the tight fit. I also will need to use Tee And Angle AN-6 fittings where the line radius whould outherwise be to tight. Tried to mock up the line first with stiff wire, but the only way that was accurate enough was to use the actual tube and accept that I was going to have a lot of scrap.
