Using a piece of household romex wire to plan the routing of the fuel lines in the cockpit. Its going to be tight. The shortest fitting side length after a radius on the fuel line can be acchived by bending the line after flaring the tube. Of course the sleeve has to be installed prior to bending. This results in a length about 1/2 dia shorter than flaring after bending.
