Bruces S-19 Build Log
S-19 Venterra
Stick grip wieing
Started wireing the stick grips. I opend up the hole in the bottom of the stick to 5/16 so that the 7 wires and expandable sheathing will fit thru a rubber grommet in the hole.
Vacuming the pull string through the stick
wires and sheathing thru the gromet
Soldering the switches
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
