Painted and installed Switches for the center panel. There are two knobs for music volume and instrument panel lights dim. A key starter lock-out switch and the one-handed momentary on lever switch/ engnie start push switch necessary to start the fuel injected Rotax 912is engine. In addition under a maintainance access door there is the engine ECU Can buss read plug, the ELT test switch and light and two EFIS USB ports for updating the Dynon software or used for database memory, positioned so that a memory stick will be held in place when the door is closed. Time to work on the big panel!
