I checked various ground wire paths and possible shielding to minimise static due to the position light/strobe. The position light adds a little static to the VOR signal, The Strobe only adds static when it gets hot. I used a hand held radio pluged into the tip antenna to check. The best wire run is per the antenna installation instructions,
