Bruces S-19 Build Log
S-19 Venterra
Layed-up a fiberglass fwd tip skin
Bent the lay-up table over a pipe same as used for the metal tip skin and layed-up the fwd tip skin. Same skin laminate thickness as the aft skin.
Vacuum baged skin
peel ply can be hard to remove
finished skin ready to trim
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
