The Pulsar Nav/Strobe lights have a resistor or somthing on the wire pigtail, so there has to be a long wire run to enable the wire to be pulled out of the tip for maintainance. Tis made it necessary to design a wire bracket that prevents the wire loop from floping aroud in the tip but allows the wire to be pulled out. Designed, built same and installed tip.
Wire Bracket
bracket installed wire can be pulled out about 4 inches
