Bruces S-19 Build Log
S-19 Venterra
Pressure tested tank with home-made manometer
Leak tested the RHS fuel tank same as the LHS tank last year. How time flys! As on the LHS tank I have a small leak under the fuel cap.
Manometer set-up
3.5 ft = 1.5 psi
air valve and water reseivour
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
