Bruces S-19 Build Log
Date:  4-10-2013
Number of Hours:  6.00
Brief Description:  Bending ADAHRS Tubes
I had some fustration with bendig the Pitot/Static/AOA tubes for the ADAHRS. I first tried to do it freehand with a heat gun. Very dificult the tube would kink just after it got hot enough to bend. What I found to work best is to heat the tube on a mandral. I used a aluminum tube bending tool. Put the plastic tube on it and then applied heat with the gun and worked the tube around the tool.
seems like the best way to bend plastic tubing
Keep it on the bending tool, not free-hand!
