Bruces S-19 Build Log
Date:  12-19-2012
Number of Hours:  5.00
Brief Description:  Built a wing tip Nav/Strobe light bracket
Built a bracket for supporting the tip light on the non-reinforced plastic tip rib. Formed the bracket using steves Harbor Freight brake over a 3/8' wood dowl pin. Match drilled to the light attachment bracket and rib. I made the bracket from 0.25 6061-T6. I am using Aeroleds Pulsar NAV/Strobe/Position lights.
Harbor Freight bending break
Finished bracket with AeroLed lights
bracket in place on the inside of the tip rib
