Formed the tip LE skin over a 1" dia pipe. Aligned and drilled the tip skins to the aileron. Carefully trimed the plastic end rib to fit. Drilled to full size #30.
hand formed LE over a pipe
Aligned to the aileron
For access, the upper mid skin is the best close-out skin
