Built and installed a ELT bracket to fit between the ribs under the cargo floor. I didn't want to mount the ELT directly to the thin fuselage skin. This bracket, built from .032 6061-T6 should do. It took a while to figure out because the access hole is just barely big enough. Its bolted to the ribs with four screws.
