Bruces S-19 Build Log
S-19 Venterra
Built ADAHARS bracket
Built the bracket from 0.05 2024-T0. I bent it to shape using a form block. Normaly I would'nt use T0 aluminum but it is just as stiff as tempered Al and bends easlly and its what I have, with the .050 gage, strength is not an issue.
cut out shape
top and bottom form blocks
trial fit
S-19 Venterra Home
1984
Aft Fuselage
Aileron
Assembly
Builder
Center Fuselage
Cowling
Demo Flight
Distractions
Fiberglass Tip for V
Flaps
Flight Test
Forward Fuselage
FWF
Horiz Stabilator
Instruments
Interiour
Project
Seats
Shop
Tips
Trim Tab
Vertical Stablizer
440
